E ErikaT Honorable Aug 18, 2012 26 0 10,530 Sep 12, 2012 #1 hi My HD7750 detects my HDTV through HDMI and play videos well. However, in the play back devices option, it always say the TV is not plug in Please help regards
T te100 Distinguished Aug 8, 2004 1,336 0 19,660 Sep 12, 2012 #2 ErikaT : hi My HD7750 detects my HDTV through HDMI and play videos well. However, in the play back devices option, it always say the TV is not plug in Please help regards I just tried it on my 5670 and it works great. do as oxford373 suggests Upvote 0 Downvote
O oxford373 Distinguished Jun 22, 2009 618 0 19,060 Sep 12, 2012 #3 4xxx,5xxx,6xxx,7xxx AMD graphics card can do 7.1 audio over HDMI http://www.tomshardware.com/forum/257300-31-video-card-htpc-hdmi-audio here is how to enable audio over HDMI http://support.amd.com/us/kbarticles/Pages/GPU70NoAudiofromHDTV.aspx Upvote 0 Downvote
E ErikaT Honorable Aug 18, 2012 26 0 10,530 Sep 12, 2012 #4 i have gone to google my problem, and the solution is to unplug my DVI and the sound will go to HDMI, is so trouble some to unplug and plug Upvote 0 Downvote
spat55 Distinguished Jun 4, 2012 2,175 0 20,160 Sep 12, 2012 #5 BTW to check playback options go to the speaker in the corner of your taskbar and right click, then go to playback options. Upvote 0 Downvote
spat55 Distinguished Jun 4, 2012 2,175 0 20,160 Sep 12, 2012 #6 Check the playback options and make sure you have your GPU selected. Upvote 0 Downvote
E ErikaT Honorable Aug 18, 2012 26 0 10,530 Sep 12, 2012 #7 it always shown as not plug in Upvote 0 Downvote
