Need Advice, Go to Single GPU or Stay with SLI
APPROXIMATE PURCHASE DATE: within the next 2 weeks BUDGET RANGE: up to $300 before rebates
USAGE FROM MOST TO LEAST IMPORTANT: Gaming. I play Star Wars: The Old Republic
CURRENT GPU AND POWER SUPPLY: I currently have 2 NVIDIA 9500GT running SLI and have an Ultra X4 800W P/S
OTHER RELEVANT SYSTEM SPECS: AMD Phenom X4 945 CPU 3.0GHz, Win7 64-bit Ultimate, 8GB Ram, MSI NF980-G65 MoBo
PREFERRED WEBSITE(S) FOR PARTS: newegg.com, compusa store COUNTRY OF ORIGIN: USA
PARTS PREFERENCES: NVIDIA
OVERCLOCKING: Maybe SLI : Yes
MONITOR RESOLUTION: 1920x1080
ADDITIONAL COMMENTS: My Question is would I benefit from just having a single GPU (like a 560Ti) or running two of the same graphics cards like I am running now
2 answers Last reply
More about need advice single stay
  1. In your price range and situation, I would definitely go for a single more powerful GPU.
    I would also wait a few days to see the GTX 660 (non TI) reviews and price on release. You might like the GTX 660 or 660 TI for that setup. I would recommend a Kepler (600) card since your system looks good enough for it.
  2. +1 Single GPU (emphatically!!)
    Your original setup was kind of weak - low power cards should really never be put in SLI. Part of the power is wasted in the sharing process. Only get SLI if you can't get a single card in your performance range/budget.
    Edit: also if you havent read it you should read this months GPU guide --
    http://www.tomshardware.com/reviews/gaming-graphics-card-review,3107.html
Graphics Cards GPUs SLI Graphics Product
