Travel help
osamabinpwnn
i didn't really know where else to put this but i just wanted to know if there will be any problems with airport security if i travel with electronic components such as cpu's, motherboards etc.
alos wanted to know if all the computer components necessary for building a pc will fit in a standard carry on bag (not including case).
p.s. i am planning on transporting the parts from Canada to Mexico.
if the parts matter here is a list of them
Motherboard: ASRock z77 EXTREME 4M
CPU: Intel Core i5 3570k
CPU cooler: NH-D14
Graphics card: XFX AMD Radeon HD7770 1GB
Memory:G.SKILL Ares Series 16GB (2 x 8GB)
Storage: Mushkin Enhanced Chronos Deluxe MKNSSDCR240GB-DX 2.5" 240GB SATA III MLC Internal Solid State Drive (SSD)
Power supply: KINGWIN Lazer Platinum Series LZP-550 550W ATX 12V v2.2
Fans: 3x120mm noctuas and 1x 200mm corsair fan
Extras: LG Electronics 10X Blu-Ray SATA Writer
CPU cooler: NH-D14
answer
Last reply
More about travel help
New Build
Systems
Related Resources
- HELP travelling
- Travelling with electronics
- Help Choosing Parts
- Intel SSD 510-Series 250 GB Review: Adopting 6 Gb/s SATA
- Help me find components
- HTPC - Component Overkill for Processing Needs? Help Please
- Is This A Decent Gaming PC?
- Need advice on new build component choices
- Component Compatibility Check
- Benefits of solid state drive?- $1000 build
- First Computer Build Component Check
- New build components, comments and suggestions~~parts already here.
- Gaming Computer
- Building my New Machine!
- Help choosing Solid State Drive!
- Corsair F60 2.5" sata 60GB solid state drive
- Internal SATA to SATA transfer speeds at 20Mb/sec... Please Help!
- Is CORSAIR CX Series CX750 750W a good power supply?
- Intel vs Amd
- Best solid state
