New System HELP!!!
Last response: in Systems
November 9, 2012 2:10:34 PM
Hi, i need to upgrade my whole system from my ageing core 2 duo platform. I have considered 2 options, one is to get a APU, one is to get a old fashioned CPU+GPU.
These are the 2 systems i have in mind. Which one is better? Please don't tell me to go intel because i don't have the money
System 1:
AMD FX4130 3.8GHz quad core.
Asus M5A97 AM3+
4/8GB's ddr3
Geforce gtx280 1gb ddr3
System 2:
AMD Trinity a10 5800k w/ 7760D Graphics.
Gigabyte GA-F2A75M-D3H
4/8GB's ddr3
I already have a PSU, hard drive, dvd drive and case.
The games i want to play are battlefield 3, just cause 2 and future games like that at 1080P. I am suspecting the 1st system will be better, but someone told me that the APU was better, help!!
I also have a problem with one of the builds, system 1, the motherboard has a 8pin cpu connector and my psu only has a 4pin, will it work, the cpu is a used 125W one?
Thanks!
More about : system
November 9, 2012 2:14:46 PM
How much is your budget exactly?
I would get the 2nd build. FX-4130 is a Bulldozer line and they're not very great in gaming. I doubt the GTX280 would be any better than the APU's IGP as well.
November 9, 2012 2:23:48 PM
Even if i overcocked system 1 to 4.8GHz?!?!
And got a GTX285?
Also, the motherboard has a 8pin and my psu has a 4pin, will this be a problem??
Thanks!
November 9, 2012 2:31:47 PM
£160 for cpu, motherboard and graphics card, tight eh?
November 9, 2012 2:37:01 PM
hmm, probably the apu.
November 9, 2012 2:41:25 PM
Really? I'm stunned!
