Hello, Right now I am just finishing converting my loft into a bedroom and I am also installing an Ethernet outlet up there too.
I have already got the cat5e cable run from the router and run under the floorboards to where the outlet is going to be installed but I have come up against a bit of a problem.
How do I mount the outlet to the wall using this backplate?
Am I missing something as I cannot see where screws are meant to go. Obviously the cat5e cable goes through the hole in the back and the faceplace with keystones screws onto the front but I cannot see how this is meant to be secured to the wall.
Any help is appreciated!
Thanks.
Thanks.
