Hello, i've been lurking in these forums for a while now for a solution to my problem, but none so far.
So i've been having trouble getting my new gigabyte AMD radeon 7870 OC to work on my newly built pc.
I'm pretty sure i have everything installed correctly, PCI cables in the right place connected to my power supply, it powers on and the fans run. As soon as i connect the HDMI cable to my monitor, i don't get a signal. Only way i can actually see my display is if i use the motherboard's HDMI port. I've tried installing the driver's as well but nothing happens... tried going to my bios screen and selecting PCIe instead of auto for the graphics card slot and still nothing...
it seems like my pc isn't even detecting the card at all, and i'm pretty sure the card isn't faulty or defective since I've sent the same one i ordered back to get a new one of the same type. I check out the device manager and see no trace of the card, even though it's pushed into my motherboard all the way. I'm really stuck here and would like some help or advice, so i don't feel like i spent 200 something dollars on this thing for nothing.
Here are my specs:
OCZ 600w ModXstream power supply
Z77MX-d3h motherboard
intel core i5 2500k processor 3.30GHz
patriot gamer series RAM 32GB (8x4)
Acer 23" LED monitor
OS: windows 7 32bit
also... I'm wondering if the card not being able to be read has to do with the on-board graphics from the motherboard?
Not really sure but it would be nice if i could get that cleared up... please help.
Here are my specs:
OS: windows 7 32bit
