GTX 660 TI Bf3 Review LOW FPS! Help!
Graphics Cards
- Battlefield
Graphics
Dimitri4592
September 14, 2012 3:23:13 AM
Toms Hardware,
Please be my knight in shining armor.
Long story short, I am SLI two Geforce 660 TI. (2)
What did I want out of them? A solid 60 PLUS FPS on ultra in BF3. (1920 x 1080)
What am I getting? 30-40s.
I have tried everything! Driver sweeper, reinstall of drivers and all that good stuff
My question to you is, WHY Does this happen :|.
I just want it to work
System:
FX 8120 @ 3.1 Ghz.
Gigabyte UMD 3 FX990 Mobo
4G Vengeance RAM
800 WATT GS V2 PSU
128 GB SSD
2X 660 ti SLI
. My question to you is, WHY Does this happen :|.
System:
FX 8120 @ 3.1 Ghz.
4G Vengeance RAM
800 WATT GS V2 PSU
128 GB SSD
2X 660 ti SLI
More about : gtx 660 bf3 review low fps
Dimitri4592
September 14, 2012 3:28:12 AM
chase3567
September 14, 2012 3:28:48 AM
Dimitri4592 said:
Toms Hardware, Please be my knight in shining armor.
System:
FX 8120 @ 3.1 Ghz.
4G Vengeance RAM
800 WATT GS V2 PSU
128 GB SSD
2X 660 ti SLI
What is your GPU/CPU usage during gameplay? Over clock the 8120 a bit.
m
l
- My friends GTX 660 Ti is running 20-30 fps lower than mine in BF3 - Tech Support
- Amd fx-4100 and gtx 660ti bad fps in bf3 - Forum
- GTX 660 Ti Very Low FPS for most games - Tech Support
- Low FPS on Minecraft with GTX 660 Ti? - Tech Support
- Low Fps GTX 660 TI - Tech Support
Dimitri4592
September 14, 2012 3:29:19 AM
Dimitri4592
September 14, 2012 3:30:03 AM
chase3567
September 14, 2012 3:33:39 AM
Dimitri4592
September 14, 2012 3:34:28 AM
Dimitri4592
September 14, 2012 3:38:38 AM
make sure your running the newest bios on your mb. use cpu-z and look at your ram info in the spd tab. make sure your ram running at it max rated speed. make sure you got the newest mb chipset drivers from amd. make sure with gpu-z both cards are read right and the bus speeds are right. ie 8x 8x for each card. in the games and nvidia control panel. make sure you have the slider set to performance by default it in the middle between performance and quality. under global setting if you have one monitor set it up and turn off power savings. you may have to tweek v-sink and other setting there like tripple buffering.
most time the kiler is aa and aafx. game or nvidia set it to 8 or 16x...try turning it down and see if your frame rate goes up.
m
l
chase3567
September 14, 2012 4:21:28 AM
evan1715
September 14, 2012 4:33:33 AM
Dimitri4592
September 14, 2012 4:53:04 AM
evan1715
September 14, 2012 5:10:23 AM
drinkingcola86
September 14, 2012 5:30:55 AM
iDaveeFTW
September 15, 2012 11:43:45 AM
chase3567
September 16, 2012 2:58:44 PM
envy14tpe said:
wait. Your not at 100% load while running BF3? What? You got to throttle that harder. Kinda curious. Why did you SLI 660Ti s? You could have bought a 680 and kicked ass.
New benchmarks were just done and two 660's actually beat one 680. If were buying new cards personally I would just get one 680 tho.
m
l
lufihengr
November 3, 2012 7:47:33 PM
Limerick
November 3, 2012 8:16:26 PM
System Analysis Program
April 11, 2013 7:21:58 PM
smorizio said:
make sure your running the newest bios on your mb. use cpu-z and look at your ram info in the spd tab. make sure your ram running at it max rated speed. make sure you got the newest mb chipset drivers from amd. make sure with gpu-z both cards are read right and the bus speeds are right. ie 8x 8x for each card. in the games and nvidia control panel. make sure you have the slider set to performance by default it in the middle between performance and quality. under global setting if you have one monitor set it up and turn off power savings. you may have to tweek v-sink and other setting there like tripple buffering. most time the kiler is aa and aafx. game or nvidia set it to 8 or 16x...try turning it down and see if your frame rate goes up.
I also have a similar problem, i also have dual 660 ti sli but when i go sli and ultra on bf3, fps drops to 30 to 20 fps but when i disable sli and run a single card along i get better results on ultra, 60 to 50 fps with fraps. The GPU load is around 50-60 percent most of the time, sometimes up to 80% with just one 660 ti.
Is something bottle necking my PC? Thankyou
Build: i7 3770k OC 4.4 Ghz
Mobo: Sabertooth z77
Graphics Card: 660 ti
RAM: Corsair Vengeance 1600mhz 16gb
m
l
Chaos2Theory
August 18, 2013 3:18:18 PM
King Toby
August 26, 2013 7:27:07 PM
- GTX 660 Ti-Crysis 3 Low FPS Forum
- SolvedLow FPS: Phenom II X4 965/GTX 660 HELP! solution
- Gtx 660ti Super low fps Forum
- gtx 660 ti awful performance in bf3 and skyrim help!!! solution
- SolvedGTX 650 TI BOOST 2GB HELP!! Low fps :( solution
- SolvedVery low FPS PLEASE HELP! Gtx 650(non ti) solution
- Solvedsince getting a new motherboard ive had worse FPS in BF3? FPS drops of mid 40s on my 660 ti?? solution
- SolvedWHAT IN THE WORLD Do I Have to DO to GET CONSTANT 70+ FPS!??! BF3, FX 8350@ 4.7GhZ, 660 ti solution
- help plz getting low fps in far cry 3 20fps with gtx 660 :( solution
- *PLEASE HELP* low fps gtx 660 solution
- SolvedLeague of Legends low fps on 660 Ti solution
- SolvedI have low fps with GTX780TI on BF4 solution
- Solvedevga gtx 660 ti sc 3 gb max out bf3 solution
- More resources
