Will these parts work?
Last response: in Systems
:bounce:  I am going to build my first computer and I would like to know if these parts will work :D
MOBO-http://www.newegg.com/Product/Product.aspx?Item=N82E168...
CASE-http://www.newegg.com/Product/Product.aspx?Item=N82E168...
GPU-http://www.newegg.com/Product/Product.aspx?Item=N82E168...
CPU-http://www.newegg.com/Product/Product.aspx?Item=N82E168...
RAM-http://www.newegg.com/Product/Product.aspx?Item=N82E168...
SSD-http://www.newegg.com/Product/Product.aspx?Item=N82E168...
HARDDRIVE-http://www.newegg.com/Product/Product.aspx?Item=N82E168...
DAV BURNER/PLAYER-http://www.newegg.com/Product/Product.aspx?Item=N82E168...
OS-http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Please answer accurately and help me. Also I would like to be able to play Skyrim at max settings 1080p with 50 fps at DAY. And I would like to be able to play Minecraft with 100 fps all settings maxed out 1080p. Please Help :pt1cable:  Thankyou!
More about : parts work
Well you haven't listed a PSU so you'll probably need one I believe a 600w or 750w should do just fine, and make sure it has a 80+ Certificate but overall these should work together just fine...
Ask the community
