Hi,
I assembled my desktop in 2007 for gaming and was able to run any game at max settings flawlessly. I used it for 2 years and then left it untouched for 2 years.
When I started using it again, it was working fine. Everything still works fine until I try to play games (even a lowly game like Diablo 3). The screen got all messy and then eventually crashed.
I installed GPU-z and RivaTuner and saw that my GPU would get really really hot. I set the fan speed to 100% which actually allowed me to play the game and it ran VERY smoothly. However, the fan speed would change by itself sometimes and I would have to keep resetting it. While running the game, the temp would stay between 80-90. If it hit 90, the fan would automatically go to 20 or 40%. If I don't notice it, it gets hotter and hotter and crashes.
What is causing my fan to keep changing speeds? I even have RivaTuner running and set at 100%.
I have a feeling I'll probably end up buying a new vid card, but I'm not as big a gamer as I used to be so don't really want to invest another $300.
Any help is appreciate, thanks!
