Solved
First time build problems and diagnostics.
After a while trying to boot my new system up for the first time.
I got the one long beep and then 4 short beeps after changing the RAM positions.
But i can see that the RAM is fully recognized in the BIOS.
Can the RAM be defect and still recognized?
Or , is it something else?
Also as long as the system got to the BIOS means that there is not problems with the CPU ,right?
The screen i have is Samsung S27A750D connected to the graphics cards through the HDMI cable , and the bios looks weird with glitchy screen, and i can't see it all.
edit :
Connecting through the Display-port now i can see all of the screen with no problems.
I am having A0 debug LED with 1 long beep and 4 short beeps.
8 answers Last reply Best Answer
More about first time build problems diagnostics
  1. Try each memory stick individually and individually in different memory slots.
    RAM is recognized full capacity in windows 8 and in bios.
    Oh , did i forget to mention.
    They are an 8 dimm kit , so...
  3. Being recognized doesn't mean that there isn't a faulty stick that gets masked by the working sticks and/or a faulty slot that gets masked by the working slots. It's possible that you have one or more faulty memory modules and/or slots and if you want to troubleshoot the problem, you may want to test the memory properly.
    Ok , going to run memtest86
    Memtest86 Download
    ok , memtest starts but stops after less than one second.
    Going to try each ram alone.
  5. I booted , got a cpu fan error and 1 long beep and then 4 short beeps.
    Then , i ran the memtest86 the memtest passed with zero errors for that stick , then i had to go to college , and i just came back.
    In the way back i asked the resellers and he asked me where i have connected the fan connector , and it turned out that it was connected in the CPU opt connector , which cause the error and the beep , i did connect it to the right one , and finally no beeping , i will start stability testing soon.
    Your help is appreciated though.
  6. The problem is connected the fan 3-pin connector to an optional fan motherboard fan connector.
    The solution is connect the fan 3-pin connector to the main motherboard fan header controller.
    Noteworthy , i was able to proceed to windows even when i hear the beeping.
    Someone copy that to choose as best answer and solve this issue , thank you.
  7. Best answer
    Sorry, I never thought of that being the issue :(
  8. Best answer selected by Dropz.
New Build BIOS RAM Systems
