G
Guest
Guest
Motherboard: MSI Z77A-G45 Z77 Socket 1155 8 Channel HD Audio ATX Motherboard
http://www.ebuyer.com/345350-msi-lga...board-z77a-g45
Case: NZXT Source 210 Black Gaming Chassis 120mm Fan
http://www.ebuyer.com/278064-nzxt-so...an-nzxts210001
PSU: OCZ ZS Series 650W 80+ Bronze PSU with 135mm Fan & single +12V Rail
http://www.ebuyer.com/264511-ocz-zs-...-ocz-zs650w-uk
GPU: Sapphire 11200-14-20G OC Sapphire Card (2GB, HD7850, GDDR5)
http://www.amazon.co.uk/Sapphire-112...dp_ob_title_ce
Memory: G.Skill 8GB DDR3 1333 MHz Ripjaws Memory Type: 240-pin DIMM
http://www.ebuyer.com/240498-g-skill...edium=products
CPU: i5 3570k 3.4 Ivy socket
http://www.ebuyer.com/349029-intel-c...bx80637i53570k
I am wondering, will these components all fit together? will the Sapphire Radeon HD 7850 gpu work with the MSI Z77A-G45 mobo? I've heard it doesn't in some cases,.
plus I will be using my Current Dell Dimension e521 Sata2 Drive and it's optical drive inside this rig since I'm a bit strapped for cash at the moment, will these work too?
