Hello everyone! I am building a gaming PC for my friend and I would just like to know if these parts are compatible. He was initially going to buy an Alienware PC, but I told him that he could build a better one for about the same price. Anyway, I would appreciate any advice and suggestions. Thanks very much
Approximate Purchase Date: Within two to three weeks.
Budget Range: Under $1200
System Usage from Most to Least Important: Mostly gaming with casual usage.
Are you buying a monitor: After building the PC, but right now the priority is to get this rig built.
Parts to Upgrade: Everything/New build
Do you need to buy OS: Yes, Windows 7 HP 64-bit
Preferred Website(s) for Parts: Newegg & Amazon
Parts Preferences: Intel
Overclocking: Maybe, I do not know how to overclock. But I don't think its really necessary.
SLI or Crossfire: No
Your Monitor Resolution: 1920 x 1080
Additional components: None
And mostly why are you upgrading: Going into PC gaming, coming from console gaming. Better to build a PC than to buy one.
EVGA 02G-P4-2670-KR GeForce GTX 670 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130782
SONY Black SATA DVD-ROM Drive Model DDU1681S-0B - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118031
Rosewill HIVE Series HIVE-650 650W Continuous @40°C, 80 PLUS BRONZE Certified, Modular Design, Single +12V Rail, ATX12V v2.31/EPS12V ...
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182132
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
Microsoft Windows 7 Home Premium SP1 64-bit - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible with Intel ...
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
SAMSUNG 830 Series MZ-7PC064D/AM 2.5" 64GB SATA III MLC Internal Solid State Drive (SSD) Desktop Upgrade Kit
http://www.newegg.com/Product/Product.aspx?Item=N82E16820147133
-Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
-ASUS P8Z77-V LK LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1033223
Western Digital Caviar Blue 500 GB SATA III 7200 RPM 16 MB Cache Bulk/OEM Desktop Hard Drive - WD5000AAKX
http://www.amazon.com/Western-Digital-Caviar-Cache-Desktop/dp/B00461G3MS/ref=sr_1_1?ie=UTF8&qid=1352585956&sr=8-1&keywords=western+digital+caviar+blue
NZXT Phantom 410 Mid Tower USB 3.0 Gaming Case - White
http://www.amazon.com/NZXT-Phantom-Tower-Gaming-Case/dp/B006I2H04I/ref=sr_1_3?ie=UTF8&qid=1352585985&sr=8-3&keywords=nzxt+phantom+410
Total with discounts/rebates: $1175
I will use ShopRunner for 2-day shipping
