Approximate Purchase Date: e.g.: Nov-Mid Dec 2012
Budget Range: MAX $1100; Before Rebates; Before Shipping
System Usage from Most to Least Important: Gaming; Music Production; Coding; Internet
Are you buying a monitor: Yes, 2 if possible
Do you need to buy OS: No
Preferred Website(s) for Parts: Canada Computers or Amazon.ca
Parts Preferences: Prefer Intel motherboard for better future-proofing. No preference on Nvidia/ATI GFX cards.
Overclocking: Maybe
SLI or Crossfire: Maybe
Your Monitor Resolution: 1920x1080 (not 100% sure on that, but I'd be happy with this res)
Additional Comments: I'd like to run every game out there without too much difficulty. I prefer steady frames over 'Ultra' GFX settings, but I'd like the machine to be able to run everything on high fairly well and be fairly future-proof, but cost-effective. I also don't need a crazy large monitor with a high resolution.
And Most Importantly, Why Are You Upgrading: I'm using 2 laptops; the one I use for gaming has an i3-330M and a Mobility Radeon 5650. It's served me well but I'd like something more up-to-date. I can't really run the Witcher 2 for example. Also, I'd like to finally build a custom machine.
Parts I've selected:
Antec Three Hundred Two Premium AB All Black Gaming Series Mid-ATX w/ 1x 140mm Blue Twocool / 2x 120mm Blue Twocool -- *Canada Computers Exclusive* - $74.99
Corsair Builder Series CX600 V2 600 Watt 80 PLUS Bronze Certified Power Supply - $59.99
Asus P8Z77-M PRO Socket 1155 Intel Z77 Chipset - $129.99
Intel Core i5-3570K - $229.99
Cooler Master Hyper 212 EVO Direct Heat Pipe CPU Cooler R2 - $34.99
Kingston HyperX Predator 8GB (2x4GB) DDR3 1600MHz - $39.99
OCZ Vertex 4 128GB SATA3 6GB/s 2.5" SSD - $104.99
Sapphire (11200-07-20G) AMD Radeon HD 7850 2GB GDDR5 - $199.99
Samsung S22B300H 21.5" Widescreen LED Monitor (Dual Screen Bundle) - $199.98
Logitech (920-002950) MK260 Wireless Desktop Combo (Retail Box) - $24.99
Total: $1099.89 Before tax (I'd like to bring the cost down if possible)
I know there's probably a few things I need to switch around so I could really use a second or third opinion. Thanks!
Overclocking: Maybe
