Hello, Tomshardware. I need you guys to help me check this rig before i buy it next week. First of all is a list of what i want to do with this rig:
Budget Range: 800-950
System Usage from Most to Least Important: gaming ( LoL, wow, far cry, torchlight2, Diablo3 ,...), watching movies ( me and my brothers are movie lover ), surf the web, and do a little bit of video editing.
Are you buying a monitor: No
I already have a 1900-1080 monitor.
Overclocking: Maybe
SLI or Crossfire: Maybe
And here is what I have done so far:
Mobo: Gigabyte Intel Z77 LGA1155 AMD CrossFireX W/HDMI,DVI Dual UEFI BIOS ATX Motherboard GA-Z77-D3H ( $119.99)
http://www.amazon.com/gp/product/B007R21K9E/ref=as_li_ss_tl? ie=UTF8&camp=1789&creative=390957&creativeASIN=B007R21K9E&linkCode=as2&tag=c09_11-20
Or ASUS P8Z77-V LK LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS ( $ 129.99)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131837
So, which one is better for my rig? I am really confused about mobo so mayby none of them
CPU: Intel Core i5-3570K ( $219.99)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
GPU: SAPPHIRERadeon HD 7850 OC 2GB 256-bit GDDR5 ($199.99)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102984#top
Ram: CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) ( $40.99)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145345
Fan: COOLER MASTER Hyper 212 Plus ( $29.99)
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
DVDrom: ASUS 24X DVD Burner ( $16.99)
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
HDD: Western Digital Caviar Black 1 TB OEM ( $97.99)
Case: Cooler Master HAF 912 ( $57.99)
http://www.amazon.com/Cooler-Master-HAF-912-RC-912-KKN1/dp/rebates/B003ZM7YTA
Power Supply: Corsair Builder Series CX 600 Watt ( 74.99)
http://www.amazon.com/Corsair-Builder-Series-Watt-CX600/dp/B0092ML0OC/ref=dp_ob_title_ce
Total: 859-869 -$30 after rebate,
Do you think i need a sound card for this rig since I love watching movie. So, sound is really a matter. If i do, can you guys give me some suggestions on what sound card should i buy, i can spent extra $140 for it. Is everything above fits in the case, or is the gpu fits in the mobo? Is there any possibly change that can make to shrink the budget? Every comments are welcome. And thanks a lot for spent your precious time to helping me here. And, my sincerely apology for any of the grammar mistakes due to the fact that i am not English speaker .
Overclocking: Maybe
