Will this build work?
Hello, I am new around here and i really love computers. I am actually taking PC Repair and Maintenance at my high school. :)
Anyway, I was looking to build my own gaming computer that i could play games such as Skyrim, BF3, Minecraft, Counter Strike etc. and i wanted to know if this all fits together and would work together.
Thanks in advance,
Kroinz
Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
CORSAIR Enthusiast Series TX650 V2 650W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020
ASUS P8Z77-V LK LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131837
ASUS 24X DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model DRW-24B1ST/BLK/B/AS - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9B
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145345
Antec Three Hundred Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
EVGA SuperClocked 02G-P4-2662-KR GeForce GTX 660 2GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130826
Seagate Barracuda ES ST3500630NS 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148855
7 answers Last reply
More about will build work
  1. Actually, that build seems pretty fine.
    The only thing I would change is that a 650W is too much if you plan on only using 1 GPU. 500 will do you fine
    And, EVGA coolers aren't the best. Get Gigabyte, Asus, MSI and other brands for slightly lower temps. Won't really affect performance though.
  2. Thank you so much do you think this is the best bang for the buck as well?
  3. Well , if you plan on overclocking, you will need an aftermarket CPU cooler. I'd recommend the CM Hyper 212 EVO for a moderate overclock. If not, save a bit of money and get the i5 3470. I wouldn't advise that if you get the 3570k then try to put the CPU cooler on later. You will have to take everything apart and take off the motherboard from the case, which makes installing the cooler even more of a pain.
  4. I would change the GPU to a 7870. It outperforms the 660 in every way, and it's at about the same price point.
    Will the 7870 fit on this motherboard? Will it work?
  6. Also if anyone knows a good gaming mouse keyboard around 100$ and a monitor for around 150$ it would be great
  7. ^ All GPU's fit in the PCI-E lanes on your motherboard :P
    I I would recommend is:
    Mouse: Tt eSPORTS BLACK This mouse has all your goodies like adjustable DPI up to 4000, LED Eye candy, a rubber coating, and a weighting system.
    Keyboard: Microsoft Sidewinder X4 Comes with all red LED backlit lights. Also comes with 6 macro keys & a wrist rest.
    Monitor: Anything 1080p, and 24" is fine. I would recommend ASUS as a brand.
New Build Systems Product
