My wife has an aging latitude d820. It was having a few problems so I added memory, did a clean install of windows xp. The only thing that remains a problem is it keeps dropping the connection from our router. the other computers are fine so I am pretty sure it is not the router. According to the specs the only thing that looks like the wirelss card is listed as: Card, Network, Minicard, 3945ULD Dell Americas Organization. Two questions
1) is there a way to test it to make sure I need to replace it
2) Do I have to replace the minicard or can I just cheat and get her a USB or express card wireless adapter. I assume I will have to uninstall the card first if that is the case?
thanks all
adam
thanks all
adam
