Hi,
Approximate Purchase Date: next week
Budget Range: ~$2000
System Usage from Most to Least Important: Gaming , video editing
Are you buying a monitor: No
Do you need to buy OS: No
Preferred Website(s) for Parts: Newegg
Overclocking: Yes
SLI or Crossfire: Maybe
Additional Comments:
This is my first time I build a pc. Im not sure if all the piece are compatible.
Cpu: Intel Core i7-2600K Sandy Bridge 3.4GHz
$319.99
Gpu: Gigabyte GeForce GTX 680 or Radeon HD 7970
$504.99 - 499.99
Mobo: ASUS Sabertooth X79 or ASUS Maximus V EXTREME
$334.99 - 397.99
Psu: CORSAIR HX Series HX850
$179.99
Memory: CORSAIR Vengeance 16GB (4 x 4GB)
$75.99
Cooler: CORSAIR Hydro Series H100
$117.99
Case COOLER MASTER HAF X
$179.99
Hdd: Western Digital WD Black 1TB
$109.99
Optical Drive: ASUS 24X DVD Burner
$19.99
Total: $1843.91
Thanks.
Overclocking: Yes
$319.99
$504.99 - 499.99
$334.99 - 397.99
$179.99
$75.99
$117.99
$179.99
$109.99
$19.99
Total: $1843.91
Thanks.
