Approximate Purchase Date:
If it is around 300 I'll probably be getting it with in two weeks.
Budget Range:
MAX 350.
After shippingz.
I don't do rebates.
System Usage from Most to Least Important:
Gaming.
I want to play new gen games!
Are you buying a monitor:
No.
Parts to Upgrade:
I am only keeping my PSU/GPU/CPU/HDD/DVD.
I have:
EVGA GTX 560
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130661
SeaSonic 520W modular PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151093
AMD FX 6100 (Buying from friend for 50 dollars. Not included in targeted price.)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103962
I simply require a case, mobo, and ram that won't cause a bottleneck to my Video Card!
QUESTION
Will FX 6100 bottleneck my GPU?
Do you need to buy OS:
No.
Preferred Website for Parts:
Newegg
Texas (78209)
Parts Preferences:
None.
Overclocking:
Maybe.
SLI or Crossfire:
No.
Your Monitor Resolution:
1440x900
Additional Comments:
Currently I have the GTX 560 TI and my Seasonic 520W hooked up to an old AM2 mobo with 8gb of DDR2 ram, and a tri core AM3 CPU.
But I'm definitely not getting what I want in games, I'm tired of having horrible FPS (less than 20).
Budget Range:
MAX 350.
After shippingz.
I don't do rebates.
Gaming.
No.
Parts to Upgrade:
I have:
EVGA GTX 560
QUESTION
No.
Newegg
Texas (78209)
Parts Preferences:
None.
Overclocking:
Maybe.
SLI or Crossfire:
No.
1440x900
