Can these parts work together
i am building a new pc and i want to know if these will work together corectly
Case: $274.99
Corsair Obsidian Series 800D
Will keep components cool and allow people to see very cool components.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139001&Tpk=Corsair%20Obsidian%20Series%20800D
Power supply $144.99
CORSAIR HX Series HX750 750W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010
Motherboard: $159.99
MSI Z77A-G45 Thunderbolt LGA 1155 Intel Z77
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130665
compatible with processor and can easily fix screw ups with bios usb recovery. Also includes bluetooth for gaming mouse.
Cpu: $319.99
Intel Core i7-3770K Ivy Bridge 3.5GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116501
Graphics Card: MSi GTX 670 {dual sls mounted} $779.98
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127685
heatsink for cpu $80.99
Noctua NH-D14
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608018
Memory: $85.99
CORSAIR Vengeance 16GB (2 x 8GB) CMZ16GX3M2A1866C10R
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233277&Tpk=CMZ16GX3M2A1866C10R#top
Wireless card: TP-LINK TL-WDN4800 Wireless N Dual Band Adapter IEEE 802.11a/b/g/n PCI Express x1
http://www.newegg.com/Product/Product.aspx?Item=N82E16833704133
hard drives:
boot drive: $139.99
Intel 520 Series Cherryville SSDSC2CW120A3K5 2.5" 120GB SATA III MLC
http://www.newegg.com/Product/Product.aspx?Item=N82E16820167093
secondary drive: $99.99
Western Digital WD RE4 WD5003ABYX 500GB 7200 RPM 64MB Cache SATA 3.0Gb/s 3.5
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136697
Optical drive: $69.99
LITE-ON Black 12X BD-R 2X BD-RE 16X DVD
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106369&nm_mc=OTC-pr1c3grabb3r&cm_mmc=OTC-pr1c3grabb3r-_-Blu-Ray+Burners-_-Lite-On-_-27106369
total price:
$274.99
$144.99
$159.99
$319.99
$779.98
$80.99
$85.99
$139.99
$99.99
$69.99
______
2156.89
7 answers Last reply
More about parts work together
  1. You are wasting your money.
  2. What for you need build like this.
    Here's alternate way to spend 2000$ more rationally
    http://www.tomshardware.com/reviews/pc-building-overclocking-buyers-guide,3277.html
    Why don't you fill out sticky so we can help you more:
    http://www.tomshardware.co.uk/forum/353572-13-build-upgrade-advice
  3. Some of the products on your list are very overpriced for what they do but ignoring that and answering the question they will all work together. I can't see any issues with it.
  4. could you tell me which parts are overpriced and alliteratives with equal performance
  5. You forgot a monitor...a part that many gamers neglect the most.
    go at least 27" and 2560x1440 ( recommended) or regular 1080 or 1200
    I would strongly suggest avoiding SLI or CF do a single card solution so 680 or 7970Ghz
    useing hd tv as a monitor also what is the effect of useing SLI instead of one card
  7. Unless you will water cool graphic cards, SLI or CF generates a lot of noise and heat. The other thing is since you are using HD TV (1920x1080) SLI is overkill^2
    You should really save up on a good quality monitor. Forget the TVs...
New Build Systems Product
