Is my power supply good enough for gtx 550 ti
coooool
8
Hello,
i have a core 2 duo e 84oo processor in my computer which takes about 65 w (checked in wikipedia) currently there is a power supply of 305 w installed in my computer. i read that gtx 550 ti needs about 110 w.would my current power supply be enough?a 400 w power supply has been recommended for this card.for the record i am successfully runing an hd 6570 card which also need 400 w power supply (read on amd.com) i am gonna write down the model of power supply actually i have a dell optiplex 755 so its a dell power supply model no.l305p-01 dell p/n:nh493
snipersam15
167
450 to 500w is a recommended not a requirement in some cases depending on how power efficient the card is and what quality PSU you have, will determine if it will work. But in more cases than not its better to have at-least the minimum.
coooool
8
so should i buy the card and use it with my current power supply? i dont have the money to buy a new power supply i can only get the card so help me out here
snipersam15
167
I want to say yes, but you might end up getting and and not being able to use it until you get a new psu.
Ill do some more research what gpu is your 6570 is it an oem or a 1gb or 2gb give me all details you can about it
snipersam15
167
Accoarding to this the 550 ti is going to use more than 2x the power sooo I think it might be a no go on the buy until you get a new psu. If it was somewhat close like within 10-20% id say maybe but the difference is too much here.
http://www.hwcompare.com/10534/geforce-gtx-550-ti-vs-radeon-hd-6570-oem-2gb/
snipersam15
167
You may be able to get away with a http://www.hwcompare.com/11888/radeon-hd-6570-oem-2gb-vs-radeon-hd-7770/
and the 7750 is only 5w more http://www.hwcompare.com/11735/radeon-hd-6570-oem-2gb-vs-radeon-hd-7750/
I know those aren't the graphics cards your looking to buy but its still a good upgrade choice based on psu restrictions.
coooool
8
well i have 2 gb ddr3 saphphire amd radeon hd 6570 card
having a core core clock of 650 mhz 128 bits
coooool
8
but mine is 2gb ddr3,wouldn't it make a difference.the one given in this website is a ddr5
coooool
8
ok what if i buy the 550 ti and try to run it on my current pc? is there any risk involved? i mean i may buy the card and if it does not work i may use it latter when i am able to get a new power supply.i can use my 6570 till then but i want to be sure that testting the card on my current system wont do any permanent damage.i hope u get my point
