I5 3570k and 6850 on 500 watts power supply
Last response: in Systems
Homebuilt system Expert
Power supply Expert
http://www.eggxpert.com/forums/thread/323050.aspx
That PSU is listed in tier 5 out of 5 for horrible quality. That's the sort of PSU that should be replaced ASAP.
http://realhardtechx.com/index_archivos/Page680.htm
Looking here, we can see that it's made by FSP and that's also not a good sign.
I can't find a professional review for it for further clarification, but I think that it's best to recommend getting a new power supply such as this:
http://pcpartpicker.com/part/antec-power-supply-bp550pl...
Or this:
http://pcpartpicker.com/part/xfx-power-supply-p1550sxxb...
Related ressources
Cooler Master extreme II?
For a PSU, I would recommend a Corsair TX V2 or TX M.
Most XFX and Seasonic PSU's are also good.
If you want a Cooler Master, The Silent Pro is a good choice.
I know it's hard to spend a lot on a power supply, but it's just not worth risking it.
mastrom101 said:
430W is cutting it a bit close...
no it's not. trust me, it's really not. 430W is fine for that rig plus major overclocking. 380W would even be fine. This is provided that the PSU is somewhat reputable, of course, like the corsair i suggested or seasonic, antec, etc. here's a good article that shows this...
http://www.tomshardware.com/reviews/phenom-ii-overclock...
I had nearly that exact rig for a year and it was just fine.
Power supply Expert
Corsair CX430 isn't a very good PSU. The Antec VP-450 is cheaper and better in reliability and power delivery (I agree, 430W is more or less plenty, but a little more wouldn't hurt).
i defer to blazorthon, but personally, while there are clearly better quality PSUs out there, there are far more that are MUCH worse. i think the CX430 has got a killer price/performance ratio right now. spending $15 more to get the Seasonic 430 watter is always recommended though, of course.
Power supply Expert
Like I said, it's not a very good PSU. I didn't intend to imply that it's a bad PSU. The CX 430 (v1 and V2) are decent, they're just not very good. The Antec VP-450 is an above-average unit with an even lower price than the CX 430, hence I brought it up as a superior alternative. One issue with the CX 430 is that it uses poor-quality caps and the VP-450 seems to have a considerable advantage in that, especially considering the lower price.
Homebuilt system Authority
are you sure you want to go 6850? I had it and I mean it was good but just not as good as you might hope... get the 7850 its not much more for a big jump in performance... I know its about 70 more but the jump in performance is a great deal and you will last with this card for about 2 years easy
and for the power supply yeah you can get that easy and also have some nice room for overclocking as long as you keep it like you say by only adding a 3570k and a 6850(get the 7850)
eesh...idk man...it's hard for me to say that a johnny guru recommended PSU that's 80 plus bronze, has a single instead of dual 12V rail, and has a 1 x 6+2pin pci-e connector instead of just a 6 pin and is just $5 more is inferior. not to be a butt, just sayin. :)  but based on newegg reviews alone, you gotta give it to the VP-450.
Power supply Expert
My only problem with Jonny Guru is that those reviews don't necessarily give a good impression of failure rates. They test the power supplies excellently, but they simply don't test several to several dozen units for failure rate consistency (not that I expect anyone to do such work). That's where less professional stuff such as Newegg can come in handy... Sure, they're mostly not professional reviews, but they are far greater in sample size and that can make them statistically more relevant for determining failure rates.
Also, I've used several units of both the CX 430 v1 and v2 models in many builds and I can say that overall, the VP-450 has worked out better for me in reliability, especially with loads that are kinda high for their wattage ratings.
Also, I knwo that it doesn't have the rating for it, but the VP-450 is usually about 85% efficient like the good Bronze models are supposed to be. Even at like a 550W load, it can usually retain about 81% efficiency. It doesn't have the 80+ Bronze rating just because it lacks active PFC IIRC which although may be a little less than ideal, it's worth getting an otherwise better model than perhaps all other similarly priced models in almost every way. My only problem with the VP-450 is like you mentioned it's PCIe power connector only being a six-pin, but if I really want more, getting an adapter isn't expensive at all and it can still end up cheaper than its competition even if you have to buy an adapter.
Otherwise, I'd still go for something such as the Antec EarthWatts 430 instead of the CX 430.
that is very true. i've always had a problem with that myself. however, one thing i don't like about relying on newegg reviews is that a good chunk of the bad reviews are due to people not getting their MIR checks, which negatively skews the reviews. the CX430 has MIRs all the time, as do OCZ power supplies.
Power supply Expert
Of course, you're right about that. I prefer to skim through the reviews to *cross out* those that are obviously user error or for stuff such as MIR issues.
alex92692 said:
Well I think I resolved my problem with my fps drop. It was causing by my hard drive. on western digital blue SATA2 500gig. I'll buy an SSD to see if it could be my problem.
what makes you think it's your hard drive?
Power supply Expert
An SSD is extremely unlikely to help your gaming performance, although it should help with loading time for menus and such. Gaming simply isn't really limited much at all by storage performance.
Power supply Expert
In games that mostly only use one or two cores (such as Skyrim), with two cores are maxed out, the total utilization is 50%, yet you have a huge CPU bottle-neck regardless. Furthermore, CPU utilization is not a good measure for a CPU bottle-neck anyway. Some games will load cores up to around 50-100% even if they're not bottle-necked. The opposite can happen too with a CPU not being loaded heavily on any cores, yet still being a bottle-neck.
I'm still thinking that it's my hard drive because it's lagging when the game is loading. For exemple when I look for the first time around me the game will lag but if I look around me for a second time it will be ok.
Power supply Expert
There's a simple way to find out for sure. Overclock that AMD CPU by say 20% and see if it changes anything, even if only a little. You could even temporarily disable one core just to make sure that the heat doesn't get too high.
Power supply Expert
Different games behave differently. Skyrim is a somewhat CPU bottle-necked game and beyond that, it's a game that doesn't scale well with more than one or two cores. It often doesn't run so well on older CPUs compared to how well it runs on newer CPUs, especially Intel's newer CPUs, unless you overclock.
I'm not saying that you should do something such as overclocking if you're not comfortable with doing it, just that it may be the best solution to fixing performance with your current system.
Ask the community
