First Build Help
hi i am about to order parts for my first build and i just wanted to know if everything is compatible. right now i'm setting it up for an sli build but i only want to start with one graphics card and add another later when i have more money. :)
here are the links to the parts
Graphics – http://www.amazon.com/EVGA-GeForce-SUPERCLOCKED-Graphics-02G-P4-3662-KR/dp/B008S15XA0/ref=sr_1_2?
ie=UTF8&qid=1352751199&sr=8-2&keywords=geforce+gtx+660+ti
Mobo - http://www.newegg.com/Product/Product.aspx?Item=N82E16813157293
Cpu - http://www.newegg.com/Product/Product.aspx?Item=N82E16819115233
Power - http://www.newegg.com/Product/Product.aspx?Item=N82E16817152028
Ram - http://www.newegg.com/Product/Product.aspx?Item=N82E16820145345
Case - http://www.amazon.com/Guardian-Black-Steel-Chassis-921RB-BL/dp/B004351H9G/ref=sr_1_11?ie=UTF8&qid=1352670031&sr=8-11&keywords=desktop+computer+case
ODD - http://www.amazon.com/Asus-24xDVD-RW-Serial-Internal-DRW-24B1ST/dp/B0033Z2BAQ/ref=pd_bxgy_e_text_y
Hard Drive - http://www.newegg.com/Product/Product.aspx?Item=N82E16822148725
OS - http://www.amazon.com/Windows-System-Builder-DVD-64-Bit/dp/B0094NY3R0
if there is anywhere that i can cut cost, the pieces aren't compatible, or just tips for noobs like me please let me know!
Thanks!!!
1 answer Last reply
More about first build help
  1. Use http://pcpartpicker.com/parts/partlist/ to choose your parts.
Build Compatibility Systems Product
