Graphics card problem
Hello.
My name is Ajay Kotiya.
I have spakle geforce 210 512MB graphics card. I have recently faced some problem in my pc. I have run any 3D apps on my pc like games i saw some disturbens on screen like some big dots, image scracthes and my pc is hanged. I have remove graphics card and start my pc work should be fine.
My pc config are :
JETWAY M26GT4 V2 Moterboard.
AMD Athlon X2 Dual Core with 2Ghz CPU.
2 GB RAM
80 GB HDD
Windows xp sp3
350 watt PSU
17" VGA CRT MONITOR
Can sovle this problem ? Please help.
Thank you.
1 answer Last reply
More about graphics card problem
  1. sounds like you are getting artifacts while running 3d apps....try updating your drivers to the latest ones from nvidia....also can you tell us your temps while you are in the 3d apps? use gpuz to find your video card temps...it sounds like its overheating.
Graphics Cards Graphics
