Solved
Problem with booting.
Last response: in Systems
I have just bought a new computer from cyberpower and I am not sure why this is happening. When I turn it on the video cards fan is spinning and it beeps one short time and nothing shows up on my monitor and the same thing happens with one stick of ram, but when I unplug my video card it recognizes my mouse and keyboard but I can't see anything obviously because video card is unplugged and I do not believe it is my psu being that it a 1000 watt psu off one video card.
Specs:Intel® Core™ i7-3770K 3.50 GHz 8MB Intel Smart Cache LGA1155
Asetek 510LC Liquid Cooling System 120MM Radiator & Fan (Enhanced Cooling Performance + Extreme Silent at 20dBA)
[CrossFireX] ASUS P8Z77-V LX Intel Z77 Chipset DDR3 ATX Mainboard w/ IRST, Lucid Virtu MVP, 7.1 HD Audio, GbLAN, 2x PCIe x16 (1 Gen3, 1 Gen2), 2x PCIe x1 & 3 PCI
Corsair Vengeance 8GB (4GBx2) DDR3/1866MHz Dual Channel Memory
AMD Radeon HD 7970 3GB 16X PCIe 3.0 Video Card
1,000 Watts - Cooler Master Silent Pro Gaming 80 Plus Power Supply
Western Digital Caviar Black 2TB (2TBx1) SATA-III 6.0Gb/s 64MB Cache 7200RPM HDD
-Thanks
More about : problem booting
Best solution
The single short beep on that motherboard means it has passed it's Power On Self Test (POST). I'm going to venture that you try a different video cable here. Also, your motherboard has built in video (with the 3770) that you can try with the same cable. If the cable works, you should get something out of the built in (motherboard) ports even without the graphics card inserted.
Give that a shot, see where you get.
Ask the community
