Problems with my new build.
I just recently did a new build (last Friday to be exact). I was experiencing problems with running pretty much anything, mainly games.
Every few seconds it would lock up for 1-3 seconds. Since the problem was usually occurring when playing games/using fullscreen programs I figured the video drivers were the most obvious problem. I downloaded the most recent drivers, uninstalled mine, rebooted, and installed the newer ones. The problem persisted though. After reading around I figured it might be the install of windows. I tried reinstalling last night and it froze, but that isn't all that uncommon when installing Windows 7. I retried and it got a blue screen immediately after.
Specs
CPU - Intel Core i5-3570k
Motherboard - p8z77-v lk
Ram - CORSAIR Vengeance (2 x 4GB) DDR3 1600
OS - Windows 7 Professional 64bit
I was really frustrated so I jumped the gun the do the new install of windows so I don't have any error logs.
Any ideas to what might have been causing the problem?
I will try to get windows to install and work tonight and post the error logs if I can get it to work and the problem persists.
2 answers Last reply
More about problems build
  1. Not really sure, let's try to eliminate possibilities first - have you tried setting RAM profile to XMP?
    Yes, I did this right before the reinstall, it didn't seems to help though.
New Build New Build Systems
