Solved
Need Advice and Help on a New Build!
Hello everyone and thanks in advance for your help and suggestions... Well im starting a new build and i havent been keeping up with the latest in technologies as of late.. Basically i want a fast Build, that is able to handle the tasks at hand..I do alot of video editing and encoding, and i multitask alot, i rarely play games, but if i do then i would like for it to be able to handle them quite well...I usually make a new build every 5 to 6 years, so with this build i will probably be upgrading 4-5yrs from now.. I would like to overclock just a little though maybe around 4.3-5 if possible, not anything to serious...Here are the Specs.. some things i already have and the ? marks mean havent decided on yet?
Case: Storm Trooper (full Tower)
Power Supply: Rosewill 1300W Lightning
Os : Windows 7 Professional
Ram: ? Would like to have 32Gb of memory though and would like them to be fast...havent been keeping up on these as well .. price range is from 100$ to 170$ (if its worth it in the long run) depending on the price i may buy all 8 or i may get 2 at a time...
Mobo: ?(looking at the sabretooth though) price range is from 150 to 240(maybe) (hopefully i can get a good one that will last and is able to overclock really well) and that probably have some good bells and whistles ( i wouldnt mind that)
CPU: ? Strongly looking at the 3770K (if anyone have any other suggestions feel free) (have been reading alot about the heating probs though, but this is one im still strongly looking at)
Heatsink or cooler: ? ( Been doing alot of reading the forums and the Noctua D-14 seems a solid choice) been reading alot of good about this cooler, can get it for 72 with 10% off at newegg.. also water cooling is an option as well never had it but wouldnt hurt to try if possible (h100 seems like a solid as well) so im torn between these two but alot of my favor goes toward the Noctua.. any other suggestions feel free... price range is from 70$ to 130$ at most, but if the Noctua can do pretty much what the others can do, i would just be settled with the Noctua...
SSD : ? which would be a good one to get, im looking to 200+ GB it would be my boot, dont know a quality 1 to get..
Video Card: ? I havent really been doing too much research on these, so i need help in this area alot... my Price Range is 150$ to 220$ at most would like to get a great mid range, if i can pull out an extra 30 bucks more i would...should i go with pcie 3.0?
thermal paste: ? artic silver or is there any better ones?
oh yeah advice on if the cooler would fit properly on the mobo or cpu would be appreciate and if the size of the cooler would cause me to loose a memory slot would be appreciated as well!
Well that is all i have for now if im missing anything let me know, and i really appreciate any suggestions and all of yalls help...God Bless you and Thanks alot .. oh yeah i be working 10hrs a day so if my response seems long that means im at work (work time is 3pm to 1am) so i will be checking around 2am on any new posts and responses...Peace
21 answers Last reply Best Answer
More about need advice build
  1. Best answer
    Here's two builds with extensive description from builders, built around 3770k just like you want and used for video edit, just like you do.
    http://pcpartpicker.com/b/y97
    http://pcpartpicker.com/b/xnm
    Just a quick glance to see if it suits you or not, write your response and we'll se if you want to change something. cheers
  2. Crucial M4 CT128M4SSD2 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD) thanks for the post.. it seems 128 wouldnt be so bad, but i just missed out on this deal 78.74:(
  3. i would also add that i will atleast have 3tb hdd or maybe 2 depending, im going to have 1 blu ray/drive and possible a dvd drive..
  4. i think im going to focus on narrowing down a mobo, first then i can make easier selections with the other main components
  5. For overclocking and witj 'k' cpu Z77 chipset mobo is what you need
  6. i took your advice and right now im leaning toward the ASUS P8Z77-V DELUXE ATX Intel Motherboard and GIGABYTE G1.Sniper 3 Extended ATX Intel Motherboard, the sabretooth was in the race, but i think i may go with the Deluxe, i wish the Asus Maximus V Extreme was alot cheaper, the Asrock formula was looking tempting as well.. but i may just go with the Deluxe, have alot of bells and whistles..Well i think im 85% for the Deluxe.. now should i get Water cooling or air.. Noctua D-14 or H100 ? which would be better...
    Ad i also have to find some Fast memory, what should i look for and what determines how fast it can go .. last time i was confused with the numbers 3-3-5-16< and thats all i can remember about the memory timing.. i dont know if that is fast or slow!
    Well thanks for the help God Bless! so now the choices are beginning to get easier..
  7. oh yeah i have a 10% off coupon from newegg on a cpu cooler, it expires 11/18 so i have to make a choice by then...on the cooler! air or water
  8. Asus mobo is a good choice, nothing against gigabyte is good too, which you choose is a matter of taste.
    Definetely go with air cooling, i don't like water it's just too 'messy'.
    As for the ram 1600 mhz is enough, and timings are a dark forest, just go with CL9 and avoid CL11
  9. ok thanks... but i dont know what cl9 or cl11 is (whats the difference).. umm can you give me a run down of how to determine some good memory.. what timings make it fast and all..
  10. i need alot of help choosing a video card, i dont know where to begin...after this i should be str8
  11. radeon 7970 vapor-x (from sapphire I believe.) I'll link to it if you want
  12. GeForce GTX 560 Ti
    Nice high eng card thats in your price range
    No, thats too expensive
  13. Rosewill stuff is basically newegg brand kinda like how dynex is bestbuy brand and they are either hit or miss with those. I would suggest getting a Corsair PSU they are pretty good overall.
  14. well too late now, cause i already got it...i like the colorful leds :).. what does the numbers mean for determining how fast ram is.. like the latency if its 10-10-10-27..and my price range for a video card the highest is around 250, and i will basically only be using 1 i dont know if i would ever use 2 in the future...it depends on which is the best setup...will 2 cheaper be a lil bit better than the 1?
    And for Ram i may just buy all 4 8gb together and probably wont buy any more..Im basically once i got all parts, i wont be upgrading any of the parts anytime soon or until the next 5years :)..
  15. MSI N660 Ti PE 2GD5/OC GeForce GTX 660 Ti 2GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card 274 with rebate
    XFX Double D FX-787A-CDFC Radeon HD 7870 GHz Edition 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card 229 with rebate
    EVGA 02G-P4-3660-KR GeForce GTX 660 Ti 2GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card 284w rebate
    SAPPHIRE Radeon HD 7870 GHz Edition OC 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card ( 11199-03-20G) 234 w 15$ rebate
    EVGA SuperClocked 02G-P4-2662-KR GeForce GTX 660 2GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card 229
    HIS IceQ H787Q2G2M Radeon HD 7870 GHz Edition 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card 219 w rebate
    MSI N660 TF 2GD5/OC GeForce GTX 660 2GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card 214 w rebate
    EVGA 02G-P4-2663-KR GeForce GTX 660 FTW Signature 2 2GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card $229
    EVGA SuperClocked 03G-P4-2666-KR GeForce GTX 660 3GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card $249
    these are the cards that are in my price range excluding the ones over 250.. those are just if im able to squeeze it out
    http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007709+600286742+4018&IsNodeId=1&name=%24200+-+%24300&Page=1
    this is the link page
    any suggestions... Does pcie 3.0 or 2.0 make a difference... is one quicker than the other or are they about the same speed wise
  16. It does makes differnce but your motherbo has to have pcie 3.0 slot
    i'd go with 7870
  17. which 7970? there's quite a few
  18. Asus, XFX, sapphire. Not sure but i guess HIS is also good
  19. Best answer selected by ronald1981d.
New Build New Build Systems Product
