All these parts compatible?
phaide
23
I'm putting together a new gaming rig and I think I know what I'm doing, but I'm no expert.
MOTHERBOARD: AS Rock 970 Extreme3
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157280&SortField=0&SummaryType=0&PageSize=10&SelectedRating=-1&VideoOnlyMark=False&IsFeedbackTab=true#scrollFullInfo
CPU: AMD Phenom ii x4 965
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
GPU: GTX 560 ti 2gb
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130683
RAM: G. Skill Ripjaws 8gb DDR3 1333
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231485
PSU: Corsair TX650
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020
HDD: WD Black WD1002FAEX 1TB 7200 RPM
http://www.newegg.com/Product/Product.aspx?Item=22-136-533&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=-1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Page=2
CPU Heatsink: COOLER MASTER Hyper 212 EVO
http://www.newegg.com/Product/Product.aspx?Item=35-103-099&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=-1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Page=2
CASE: AZZA Hurrican 2000
http://www.newegg.com/Product/Product.aspx?Item=N82E16811517010&SortField=0&SummaryType=0&PageSize=10&SelectedRating=-1&VideoOnlyMark=False&IsFeedbackTab=true#scrollFullInfo
DVD DRIVE: ASUS 24X DVD Burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
My power supply gonna be good enough? Will my GPU fit in that case? All around compatibility of parts? Anything going to significantly bottleneck another component? Did I forget any important parts?
It's not going to force you to use Norton anti malware software. Having just looked at that, I'm more worried about whether or not it ships with an FX-compatible BIOS. It has FX-compatible BIOS versions, but I'm not sure if it ships with them or if you have to update it yourself with an older Family 10h CPU (Sempron/Athlon II/ Phenom II on AM3).
butremor
1,563
Hi.
Made some improvements to your build.
You don't need such powerful psu.
Case is full tower so anything will fit into it
Changed ram to faster one
Changed gpu to more to more efficient PCPartPicker part list: http://pcpartpicker.com/p/nBrV
Price breakdown by merchant: http://pcpartpicker.com/p/nBrV/by_merchant/
Benchmarks: http://pcpartpicker.com/p/nBrV/benchmarks/
CPU: AMD Phenom II X4 965 Black 3.4GHz Quad-Core Processor ($89.99 @ NCIX US)
Motherboard: ASRock 970 Extreme3 ATX AM3+ Motherboard ($74.99 @ Newegg)
Memory: G.Skill Sniper 8GB (2 x 4GB) DDR3-1600 Memory ($38.99 @ Newegg)
Storage: Western Digital Caviar Black 1TB 3.5" 7200RPM Internal Hard Drive ($94.99 @ SuperBiiz)
Video Card: Asus GeForce GTX 660 2GB Video Card ($237.86 @ Newegg)
Case: Azza Hurrican 2000R ATX Full Tower Case ($124.04 @ NCIX US)
Power Supply: SeaSonic S12II 520W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($77.64 @ Newegg)
Optical Drive: Samsung SH-222BB/BEBE DVD/CD Writer ($17.99 @ CompUSA)
Total: $756.49
(Generated by PCPartPicker 2012-11-13 15:26 EST-0500)
phaide
23
If anyone else has anything to add, please post as I would like your opinion. So I can get a gtx 660 2gb for about the same as a gtx 560 ti 2gb? I think the gtx 660 2gb would be better but the fact that it's 192-bit bothers me. Does that even matter? Also, I noticed that the gtx 660 is pci express 3.0. The mobo says it's pci express 2.0. Could I use that card on that mobo? and if i went with the gtx 660, would the power supply still be enough? gtx 660 2gb or gtx 560 ti 2gb?
GTX 660 uses far less power than GTX 560/560 Ti and all PCIe 3.0 graphics cards are compatible with PCIe 2.0/2.1/1.0a/1.0/1.1 motherboards and CPUs (where applicable).
The 660 does have a mere 192 bit memory interface, but its very high memory frequency still lets it have decent memory bandwidth for its performance.
Give me a minute, I'll throw together a build for you to compare to the others.
zissou3770k
21
If your wondering if your AM3+ board will support AM3 the answer is, yes. The only difference there as that AM3+ supports higher voltage for memory and can support AMD Bulldozer. It actually is a great jumping off point for upgrading in the future. I'd stick with 1600 ram though.
My preference is Mushkin Enhanced Blackline series. 1600 8-lat or 7-lat is all you need.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820226295
Nice case. You could find something less pricier that looks just as sweet and upgrade the ram to 1600 lat-7 with the money you save :).
Mid-tower suggestion that looks similar: $79.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811235033
Unless you NEED that many bays for running a server. But this offers: 4 External 5.25" Drive Bays, 5 Internal 3.5" Drive Bays
phaide
23
Sure, my mobo supports 1600 but it has (OC) next to it which I believe means that I must mess with the bios to get it to work at that frequency. I had a problem with an ecs a780gm-a v1.1 mobo that said it supported 1066 ddr2 ram, but when I put it in and booted it was only working at 800mhz. Attempted to force it to 1066 in bios, but it just defaulted back to 800 again. Will the ram actually work at 1600mhz without having to do anything other than plug it in?
http://pcpartpicker.com/p/nDrp
CPU AMD FX-6300 $139.99 http://pcpartpicker.com/part/amd-cpu-fd6300wmhkbox
CPU Cooler Xigmatek GAIA SD1283 $29.99 http://pcpartpicker.com/part/xigmatek-cpu-cooler-gaiasd1283
Motherboard MSI 970A-G46 ATX $77.95 http://pcpartpicker.com/part/msi-motherboard-970ag46
Memory Corsair Vengeance 2x4GB DDR3-1600 $36.99 http://pcpartpicker.com/part/corsair-memory-cmz8gx3m2a1600c9
Storage Samsung 830 128GB $98.79 http://pcpartpicker.com/part/samsung-internal-hard-drive-mz7pc128bww
Western Digital Caviar Blue 1TB $74.99 http://pcpartpicker.com/part/western-digital-internal-hard-drive-wd10ezex
Video Card Gigabyte Radeon WindForce 7950 3GB $299.99 http://pcpartpicker.com/part/gigabyte-video-card-gvr795wf33gd
Case Rosewill REDBONE ATX Mid Tower $34.99 http://pcpartpicker.com/part/rosewill-case-redbone
Power Supply Antec VP-450W ATX12V $31.64 http://pcpartpicker.com/part/antec-power-supply-vp450
Optical Drive Lite-On iHAS124-04 DVD/CD Writer $17.99 http://pcpartpicker.com/part/lite-on-optical-drive-ihas124-04
Base Total: $843.31
Combo Discounts: -$22.00
Total: $821.31
A little more expensive than the others, but I went for higher performance in the process as well as with an excellent SSD. Just another set of options to consider.
phaide
23
Thanks for your suggestion blazorthon. That is a solid build, but it must be known that I will only consider Nvidia GPU's. I really should have mentioned that in my first post, sorry. I still need an answer to my question about ram that is just a few posts up. My thanks to everyone that has posted so far.
