New Build, not working, Please Help!
Hiya guys, i am stumped here. i bought a bundle a while ago, had it all running fine until one day the bundle decided to die, after long conversations with the sellers i have had a refund. now i have purchased a new Motherboard and CPU. installed them both, all seemed ok, until i turned it on. it wont load windows, which i know i had on there before because it was running. it flashes a BSOD for literally 0.5 seconds or so and restarts. i have got the stop error message 0x0000007b, ive tried pretty much everything i know. ive even tried buying an SSD and formating it in the hopes of putting 7 on it. i have done that, installed win 7 but as soon as it loads, its hangs at the win 7 splash screen.
my pc specs are:
Asus P8Z77-LVX,
Intel i5 3570k,
Corsair 4GB RAM,
60GB Agility III SSD,
Seagate Barracuda 500GB HDD,
Corsair CX600 PSU
i have been without a computer for around 8-9 months now and getting annoyed with it..
ANY idea of help would be appriciated. i cant figure this out..
thanks
1 answer Last reply
More about build working help
  1. You need to reinstall Windows when you install a new motherboard if you used OEM Windows 7.
New Build New Build Systems
