Hello,
I built a PC system about 4-5 years ago. It's been great the whole time, with few problems.
Lately my system has begun rebooting itself randomly. Usually happens about once every 3-4 days, and when it happens it sometimes happens multiple times in a night. By rebooting I mean the entire system instantly switches off as if there was a power outage and then a couple seconds later starts back up again. Probably due to a piece of hardware failing or overheating.
A couple times I got a "Overclocking failed" message on reboot. I'm not currently messing around with overclocking settings on any of my hardware. I'm not sure what this suggests..
I took it to a shop to be looked at. They fixed my hard-drive (corrupt, probably from all the random reboots), and they tested it over night and couldnt' find anything wrong, and checked all the cables.
I'm at my wits end because I don't know how to troubleshoot this on my own, or how to narrow down the problem. It's obviously hardware related. Most likely overheating I suspect. I don't know which component is causing the issue.
Can anyone offer tips on how to troubleshoot this? Is there any way to monitor the individual components so I can narrow down which one is faulty? Is there software that will create an error log? A hardware failure record that can be analyzed or examined? How can I find out what I need to do to fix this?..
Any help is greatly appreciated. If any further info is needed, let me know and I'll try to provide whatever I can.
Thanks in advance!
Thanks in advance!
