I recently purchased a Vapor-X HD 7970 from Newegg and I am having trouble getting the card to display on my monitor. After setting up my new PC using a VGA connection to my TV, I downloaded and Installed all four driver packages that were listed under the download section for this card on the Sapphire website. I then was able to plug my HDMI cable to the video card and it recognized it correctly as a 1080p display. My problem is that I want to use a single 2560x1440 Crossover 27Q monitor but when I plug in the dual link DVI-D cable from the monitor to the video card it will not display.
In the catalyst control center, I go to "desktop management" then "creating and arranging desktops" and it recognizes both displays however only the TV is enabled and when I hold my mouse over the second display it says "QHD27Q, DFP, DVI disabled". I click the small black arrow in the top right corner and my options are "Extend" or "Replace". When I click extend it says the following: "This operation is not supported based on current display configuration". Clicking on Replace makes the Apply button flash green and then return to normal.
Two other things to note are that the monitor light is an amber color which indicates that the monitor is on but not receiving a signal. Also, if I unplug the DVI-D connection, I hear the familiar device disconnected noise through my TV speakers since the HDMI cable is carrying the audio.
I would appreciate any help resolving this issue. Thanks.
