Closed
Various problems
Hello, I recently downloaded a game, Got into it once & then everything went wrong.
Nvidia display settings are not available.- You are not currently using a display attached to an nvidia GPU.-Could not initialize Direct draw.- Display driver stopped and has recovered. These messages came over attempts to get into 4 different progs. Can't find any reference to graphics card any where
More about : problems
Quote:
Just uninstall the game.
Yes, Well I don't mind doing that if it is magically going to fix 3 other 3 prog's that currently don't work. Plus the fact it took me 4 days to get it working. If I do this can I keep the download file? and just re-install later if it isn't the problem? :??:
Related ressources
americanbrian said:
You are probably plugged into the motherboard display output.
Please list your system specs.
Thanks
windows 7 home premium 64 bit (6.1,build 76010 - processor:-AMD FX-8120 eight core (8cpu's~3.1GHz) - Memory:- 4096MB RAM. Directx 11
swifty_morgan said:
not a 16bit game is it ? if so the machine is too new to run it. try dos box ......... maybe ???
No, this is a remake of JA2 that was released earlier this year. You can get it on Steam.
americanbrian said:
That processor has a built in GPU, with a corresponding display output on the motherboard.
Ehhh... No it doesn't. It's an FX series CPU, not an APU. The AMD A-series have onboard graphics, the FX chips most certainly do not. The motherboard may have onboard graphics though.
Ask the community
