How to diagnose for problems on fresh new build?
heizenbrg
155
I'm building my first pc this weekend, was wondering about the steps I should take in checking that everything functions at the desired speeds and temperatures, any recommended software for checking Memory, GPU, CPU and the rest?
That's difficult to judge because every system is different so you will get different results every time. Ideally you don't want to go above 40'C.
heizenbrg
155
thank you I understand, what I meant was that when I'm looking at the temperatures, how do o know what's too high and what's too low?
g-unit1111
heizenbrg
155
I have a i5 3570k, noctua dh-14, gtx 670, 8gb ram, 256gb ssd, 2tb hdd in a carbide 500r. So I shouldn't go above 40°C on all the components?
g-unit1111
With a D14 and Carbide 500R you'll never go above 40'C. You should be fine. What GPU are you using? Is it EVGA? Gigabyte? Asus?
heizenbrg
155
It's the Gigabyte Windforce. I'm not sure if I'm ready to build though, feels like I'm missing something. What are the crucial things to do when building?
