So I just bought a GeForce GTX 550 Ti to replace my GeForce 9600GT Superclocked 675MHZ 512MB. Main reason for buying it was because I play Diablo 3 and thought it would give a performance increase.
I FuMark in the background while I was playing tonight and took a screenshot of how my card was running. You can check it out here:
http://imageshack.us/a/img99/2733/cardr.png
As you can see, it runs at about 78 degrees and the fan speed is 60%. The memory being used isn't very much but it did get up to about 550 MB during my playing session. I had previously purchased a Radeon 7770 HD but it didn't work and would keep crashing. Don't know if it was just the card or what but I took it back for this 550.
I also took a screenshot after I was done playing the game and sitting idle for awhile: http://imageshack.us/a/img811/6008/card2y.png
Thank in advance for any help
