Hello,I really need help about my build.Here:-
Processor:Intel core i7 3770k (Q):Is this better than i7 3820??
Motherboard:Asrock Fatal1ty intel z77 professional Socket Lga1155 (Q):Asrock Extreme6 are almost same price as this.Is it same???
RAM:Corsair Vengeance DDR3 1600mhz 16gb 4 stick Ram (Q):Can anyone tell me why 2 channel is better than 4?What is the difference between the Kingston HyperX
Graphic card:MSI Nvidia Geforce GTX680 OC 2GB GDDR5 256bit (Q):This is it,im really confused what to choose,some people said gtx680 not worht it and better take gtx670.The HD7970 ghz is better than gtx670 in Anandtech benchmark.Now which card is better?gtx670,gtx680 or hd7970 ghz
Power supply:Corsair Pro series Gold AX750W Modular (Q):Is this overpower?600W enough???
CPU cooler:Cooler master Gemini 2 S524 (Q):the Evo 212 is 5$ cheaper than this,should i take the Evo212????
SSD:Intel 330 series 120gb SATA3 P/S:All parts is expensive in my country especially this one
HDD:Western caviar green 2tb 7200rpm 64MB SATA3 P/S:No changing
Case:Cooler Master Storm Trooper (Q):Mid size casing is enough?
DVD:Asus 24x DVD P/S:No changing
So the total is around 2000$ including postage.U can suggest me other parts and ill look into it.I need reply ASAP
