Archived from groups: rec.photo.digital.slr-systems (More info?)
I started with digigal cameras with a simple point and shoot. I'd now
like to evolve into a slr system.
I have a couple of older Nikon lenses that I used with my Nikon film
bodies.
A macro lens: Nikon Micro-Nikkor-P.C. Auto 1:3.5 f=55mm
A longer lens: Nikkor-Q Auto 1:3.5 f=135mm
Is there a Nikon digital body that would allow me to use these lenses?
(I am particularly fond of the macro lens for close-up work re:
geology /tissue samples) - or are the mount standards different
/evolved?
cbrs@silicondairy.net writes:
> bodies.
> /evolved?
Yes, any of them. Also the Fuji DSLRs (S1, S2, S3) and the Kodak
DSLRs.
However, the ones based on consumer bodies, including the three
Fuji's and the Nikon D100 and D70, will not *meter* with these older
lenses. Given the histogram display and the immediate feedback, I
don't find this a problem; I use my older AIS lenses quite a lot. But
some people find it a serious problem, either because of their own
habits, or the types of photography they do.
The D1 and D2, and the older Kodak models (before the 14), based on
pro-level bodies, will meter with these older lenses.
David Dyer-Bennet, <mailtod-b@dd-b.net>, <http://www.dd-b.net/dd-b/>
RKBA: <http://noguns-nomoney.com/> <http://www.dd-b.net/carry/>
Pics: <http://dd-b.lighthunters.net/> <http://www.dd-b.net/dd-b/SnapshotAlbum/>
Dragaera/Steven Brust: <http://dragaera.info/>
In article <m2ll8v5vqt.fsf@gw.dd-b.net>,
>DSLRs.
Assuming you convert the lenses to Ai.
That was it. Done. The faulty Monk was turned out into the desert where it
could believe what it liked, including the idea that it bad been done by.
It was allowed to keep its horse, since horses where so cheap to make.
-- Douglas Adams in Dirk Gently's Holistic Detective Agency
philip@pch.home.cs.vu.nl (Philip Homburg) writes:
>>DSLRs.
Hmmmm, I wasn't looking closely enough at exactly the lenses he
listed! My oldest Nikon lenses date back to 1980, and are AIS; I tend
to forget that some people may actually be using still older examples!
"David Dyer-Bennet" <dd-b@dd-b.net> wrote in message
news:m21xan3wst.fsf@gw.dd-b.net...
>>>DSLRs.
I'm using lenses from the 70's that were recently converted. Great images,
although I can't use the meter in the camera. Incredible images from my
55mm macro.
In article <8qudnT8HIMpXYKnfRVn-rw@comcast.com>,
>55mm macro.
Note that some of those lenses (but not all) can be retrofitted
with a CPU to give you at least the metering, and camera body control of
lens aperture -- though certainly not the autofocus.
I have (so far) had one lens converted -- a 180mm f2.8 Nikor,
which works flawlessly with my D70 -- unless you mind that it records
the focal length as 300 mm in the information recorded in the photos.
(It has not been a problem for me, since I don't *own* a 300mm lens to
confuse it with. :-)
The fellow who does the conversions may sometimes take longer
than the lens' owner would like, but it works nicely in my experience
based on this one example. I'm likely to send off my 20mm f2.8 next.
Enjoy,
DoN.
Email: <dnichols@d-and-d.com> | Voice (all times): (703) 938-4564
(too) near Washington D.C. | http://www.d-and-d.com/dnichols/DoN.html --- Black Holes are where God is dividing by zero ---
dnichols@d-and-d.com (DoN. Nichols) writes:
>>55mm macro.
Unfortunately, most of the ones I care about can't be. And given how
badly TTL flash works in the S2, I'm less interested than I might
otherwise be in chipping the lenses. I've also heard some recent
reports of problems with the main guy doing it.
Last I checked the 58mm f1.2 NOCT wasn't eligible (no f1.2 chips). A
couple of the others are, but it hasn't reached the top of the stack.
"some guy" <nospam@spam.com> wrote in message
news:39pgh6F5rkkaeU1@individual.net...
> Which Canon 35mm lenes will work as seemlessly as a "digital" lens?
> (For a Digital Rebel.)
If you mean EF mount lenses, all of them. If you mean FD mount lenses, none
of them.
Some of the EF mount lenses produce better images than others, we were
disappointed in the quality of the 28-105 on our 20D that worked ok with our
10D, the fisheye lenses don't have nearly the distortion that they do on
film, so on...
