I decided to piece together an APU box in a mITX form-factor to use as a HTPC.
Here's the thing- the system is drawing way to much power. The CPU is @ 60C when I sit idle in the bios. But, wait, it isn't a heatsink mounting problem, I'm pretty sure-
1) Heatsink is almost too hot to touch
2) My Kill-a-watt says the box is drawing 110 watts on boot, 50 watts at idle on the Windows desktop!!! For heavens sake, my Athlon II X3 w/ HD5670 idled at 80W.
The only things in this machine are:
1) 65W APU
2) Samsung SSD
3) Asrock FM2 mITX motherboard
4) Scythe Kozuti fan
That's it! The fan can't draw that much, and neither can the SSD. The APU seems fully functional- I installed Windows, and I'm running applications no problem. I'm thinking it's unlikely there is a short in my case wiring, because I'd smell something, it would burn more than a few amps, and the CPU wouldn't be getting so hot.
So, can the motherboard be responsible? I've been reading that this particular motherboard is not 100% reliable, but I didn't want to wait for Zotac to come out with theirs...
1) 65W APU
2) Samsung SSD
