(Newbie) Help/compatibility with build
Last response: in Systems
My first building, help appreciated.
Recently won a gigabyte geforce gtx 680 oc so I decided to try and build a new pc for myself.
Parts:
Seagate Barracuda 2TB ST2000DM001
In stock $99.00
BenQ GL2750HM 27in Widescreen LED Monitor
In stock $255.00
LG GH24NS90 24x SATA DVD-RW Drive OEM
In stock $22.00
CoolerMaster Hyper 212 EVO CPU Cooler
In stock $35.00
Corsair CMX8GX3M2A1600C9 8GB (2x4GB) DDR3
In stock $45.00
CoolerMaster HAF X Case
In stock $189.00
Intel Core i7 3770K
In stock $335.00
Corsair TX-650 V2 Power Supply
In stock $115.00
ASUS Sabertooth Z77 Motherboard
In stock $249.00
Windows 7?
Anything I'm missing or don't need? Anything unnecessary that I can substitute with something cheaper?
Can't buy from Amazon or Newegg unfortunately. I'm in Australia.
Also, I was thinking that I could spend more since I got the graphics card free so I went for 27 inch instead of 24 monitor. (buying from pccasegear which is in aus)
Also, why should I use an ssd?
Homebuilt system Master
They're quiet, no moving parts, and windows boots up in about 15 seconds from a cold start. I'll never go back to a regular drive; I don't need the space. Use a small capacity ssd for a boot device and downloading large files. 60 gb is enough.
Ask the community
