System build advice check
Hello,
I've been doing as much research as possible to build a mid-high end gaming machine. I am about to order the following but would like some advice from anyone who has built the same machine or any compatibility problems they may have encountered.
Intel Core i7 3770K Unlocked Quad Core
Corsair Cooling Hydro Series H100I CPU Cooler System
Gigabyte Z77X-UD3H
EVGA GeForce GTX 680 SC Signature 2 1097MHZ 2MB
G.SKILL F3-12800CL10Q-32GBZL Ripjawsz 32GB 4X8GB DDR3-1600 CL10
Cooler Master Silent Pro Gold 1000W ATX 12V V2.3
Crucial M4 Micron C400 SSD 256GB 2.5in Solid State Disk
ASUS BW-12B1ST Blu-Ray Writer 12X
ASUS VE247H 23.6IN Widescreen LED LCD Monitor 1920X1080 2MS
Corsair Obsidian Series 800D Full Tower Case
Thanks
Matt
1 answer Last reply
More about system build advice check
  1. It not mid range it's above it, and you don't need i7 for gaming only i5 and can make you that build but gave so little information i can't guess in the dark
    please fill out those questions, otherwise it's gonna take too long asking you those question one by one. Post answers here. After you do that we will be able to help you faster, without having to be guessing in the dark. Thanks
    http://www.tomshardware.co.uk/forum/353572-13-build-upgrade-advice
New Build Systems
