(New Build And Problems)
So just built this rig and having some problems idk if its the MB or Card i go to play games like LoL and it runs fine for hours go to run gw2/bf3/wow/rift anything that takes a little to run it crash's. When i crash my screen go's black for a few secs then it just resets then frezzes then i gotta hard boot it outta there and i have tryed alot of diffrent things if somone could help please and thanks.
Update
Corsair Carbide Series 500R White Steel structure with molded ABS plastic accent pieces ATX Mid Tower Computer Case
Model #:CC-9011013-WW
Item #:N82E16811139010
Return Policy:Standard Return Policy
In Stock
Mail in Rebate Card
Note (Add)
$139.99 $139.99
Update
Rosewill RCW-554 10ft. /Network Cable Cat 6 Blue
Model #:RCW-554
Item #:N82E16812119160
In Stock
Note (Add)
$3.49 $3.49
Update
GIGABYTE GA-Z77X-D3H LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Model #:GA-Z77X-D3H
Item #:N82E16813128546
In Stock
Mail in Rebate Card
Note (Add)
$149.99 $149.99
Update
MSI N660Ti PE 2GD5 GeForce GTX 660 Ti 2GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
Model #:N660Ti PE 2GD5
Item #:N82E16814127697
Return Policy:VGA Standard Return Policy
In Stock
Note (Add)
$299.99 $299.99
Update
CORSAIR Gaming Series GS800 800W ATX 12V v2.3 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Active PFC Power Supply
Model #:CP-9020014-NA
Item #:N82E16817139038
In Stock
Note (Add)
$139.99 $139.99
Update
Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
Model #:BX80637I53570K
Item #:N82E16819116504
Return Policy:CPU Replacement Only Return Policy
In Stock
Note (Add)
$229.99 $229.99
Update
Western Digital RE4 WD1003FBYX 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Enterprise Hard Drive -Bare Drive
Model #:WD1003FBYX
Item #:N82E16822136798
In Stock
Note (Add)
$149.99 -$30.00 Instant $119.99
Update
ASUS VW246H Glossy Black 24" 2ms(GTG) HDMI Widescreen LCD Monitor
Model #:VW246H
Item #:N82E16824236049
Return Policy:Monitor Standard Return Policy
In Stock
Note (Add)
$229.99 -$50.00 Instant $179.99
Update
Sony Optiarc 24X DVD Burner, Bulk Package Black SATA Model AD-7280S-0B - OEM
Model #:AD-7280S-0B
Item #:N82E16827118067
In Stock
Note (Add)
$17.99 $17.99
Update
Microsoft Windows 7 Home Premium SP1 64-bit - OEM
Model #:GFC-02050
Item #:N82E16832116986
Return Policy:Software Standard Return Policy
In Stock
Note (Add)
$99.99 $99.99
Update
CORSAIR CWCH60 Hydro Series H60 High Performance Liquid CPU Cooler
Model #:CWCH60
Item #:N82E16835181015
In Stock
Mail in Rebate Card
Note (Add)
$74.99 -$10.00 Instant $64.99
Update
Rosewill RTK-002 Anti-Static Wrist Strap
Model #:RTK-002
Item #:N82E16899261005
In Stock
Note (Add)
G.SKILL Ares Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-1600C9D-8GAO
More about : build problems
my first thought is driver as well. check to see if you have the latest drivers. If you updated the drivers from a previous version you might try to uninstall and totally wipe the drivers then do a fresh install.
But just to brainstorm.
Do you have all needed connections plugged into the card? Some require more than 1. Are you OC. if you are try setting them to default. check your device manager and/or dxdiag. does it show your card correctly? not to familiar with nvidia but amd has a control center where you can set it to performance/balanced/quality and difference settings per games there, can try to change these. what is your windows index showing. should be pretty high 7.x+ does it crash at initializing or after you run the game for a bit?
Ask the community
