First build cabling help
This is my first build. These are the parts:
Case: CM Storm Trooper
Motherboard: AsRock Extreme4
CPU: i5-3570K
CPU Cooler: noctua nh d14
gpu: gigabyte hd 7870 oc
hard drive 1: vertex 4
hard drive 2: barracuda
disk drive: some random lg one, it's 5.5 in
psu: 620 watts antec green power or something
The cabling is very confusing. So far, I've only got the case, mobo, ram, psu and vertex 4.
Can someone help me with the cabling?
Thanks for answering in advance :)
(I will update this when I get a new part; probably on saturday )
3 answers Last reply
More about first build cabling help
  1. http://www.tomshardware.co.uk/forum/274745-13-step-step-guide-building
    Is this what you were after?
    Ask if theres anything not covered in there :)
    Moto
    Moto
    Nah sorry, it's not in there. I can't find the cable from the psu to connect to the atx12v1 header. Also, do the chassis fans connect to the mobo?; because the fan controller is on the case
  3. If you want to use the Case fancontroller then you plug the fans into that, and a molex line from the Psu into the fancontroller to power it,
    According to the pics here, (click the picture with three dots on it to go into gallery view and its the fifth pic)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371033
    your 12v is two fourpin blocks, they will slot together to make the 8pin block and have 'CPU' printed on them,
    Moto
Build Systems Product
