Need advice on my new build!!
I am wanting to upgrade my computer which basically consists of replacing all my hardware. I am planning to purchase a new processor, motherboard, ram, ssd, and graphics card. I want to make sure I am getting the best bang for my buck. Most of the items I want to purchase are currently on sale due to Newegg's Black November deals. I am not sure if I should wait until Cyber Monday to purchase these items. I am also wondering if the items I am looking to purchase are compatible with one another. I definitely do not want to purchase something that is unnecessary or something that will not be compatible. My current setup stays pretty cool thanks to my case but would I need to consider an aftermarket cooler for my CPU?
I am currently using an Azza Solano 1000 ATX Full tower as my case and a Corsair Enthusiast 850W power supply.
My new build consists of:
CPU: Intel Core i5-3570k - http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
Motherboard: ASUS P8Z77-V - http://www.newegg.com/Product/Product.aspx?Item=N82E16813131837
Graphics Card: MSI GTX 670 - http://www.newegg.com/Product/Product.aspx?Item=N82E16814127685
SSD: Samsung 840 128gb sata 3 - http://www.newegg.com/Product/Product.aspx?Item=N82E16820147192
Ram: G Skill Ripjaws X series 1600 - http://www.newegg.com/Product/Product.aspx?Item=N82E16820231536
The CPU and motherboard are currently in a combo deal which saves me $25.
Overall this will cost me about $1050.62.
Any input would be more than appreciated. Thank you all.
2 answers Last reply
More about need advice build
  1. bump
  2. If you want to oc the cpu(the main reason people buy the k version) then you'll want a decent cooler like this one : http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
    And this mobo will be better for that : http://www.newegg.com/Product/Product.aspx?Item=N82E16813157293
    Switch to more cheaper ram : http://www.newegg.com/Product/Product.aspx?Item=N82E16820233186
    The rest i couldn't pick better.
New Build Systems Product
