Building a new gaming rig. Here are the specs:
MOBO: GIGABYTE GA-970A-UD3
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128519
CPU: AMD Phenom II X4 965
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
GPU: MSI N660 Ti PE 2GD5/OC GeForce GTX 660 Ti 2GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127696
RAM: G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
CPU HEATSINK/FAN: COOLER MASTER Hyper 212 EVO
http://www.newegg.com/Product/Product.aspx?Item=35-103-099&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=-1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Page=2
CASE: Rosewill BLACKHAWK Gaming ATX Mid Tower
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147107
DVD DRIVE: ASUS 24X DVD Burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
HDD: Western Digital WD Black WD1002FAEX
http://www.newegg.com/Product/Product.aspx?Item=22-136-533&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=-1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Page=2
I was thinking of getting this power supply, but not sure:
CORSAIR Enthusiast Series TX650
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020
ASUS's power supply calculator says that I need 700w minimum. 5 fans, 3 devices being used by usb ports and u have the other info as posted above.
http://support.asus.com/powersupply.aspx
I would like to know how accurate their estimation of power usage is. Recommend me a reliable brand PSU that exceeds my needs, but is not overkill. Keep in mind that power usage UNDER LOAD is going to be much more than idle. Oh, and I only buy from newegg, so it has to be available there.
