Solved
Having shutdown problems still
Hey,
I posted recently about having shutdown problems and I thought it had been solved but it is still occurring. I don't want to force an answer that I want to hear, but is it that the motherboard is bad? Or maybe even the CPU?
Suggestions told me to test the PSU and graphics. I tested the PSU simply by going out and getting a different one and putting it in my setup. Got the same results with a different PSU, still random shutdowns. I took out the graphics card and tried running through the onboard, still nothing different, random shutdowns(I reset the cmos too). Tried different ram, same thing. All these shutdowns took about 30mins. Then elsewhere I read a suggestion about reseating the CPU, I did that and it ran just fine for 2 days (about 10 hours total use), and it just shut down again today.
Specs if needed,
CPU: AMD Phenom II x4 945
GPU: Asus HD 4870
Ram: G.Skill Ripjaws 3x4GB
Motherboard: Asus M5A88-M
Please, any and all advice/help/anything is really appreciated.
4 answers Last reply Best Answer
More about having shutdown problems still
  1. What is your power supply make and model number?
  2. It is an OCZ700MXSP
  3. Best answer
    Check your asus bios file at the post screen; see if another newer file is available; don't flash if you already have the latest file. You'll need a usb flash drive to update the bios. If you brick your board with a bad flash, request an rma from asus and tell them simply the board won't post. No other info is necessary. http://www.asus.com/Motherboards/AMD_AM3Plus/M5A88M/#download. You may also rma your power supply.
  4. Best answer selected by duc561.
Homebuilt Shutdown Systems
