rick123123 said:
Hey everyone,
This is my first time building a computer and i'd like some help if you could. So far i only have the motherboard, and storage. I have another $3-400 for the last remaining parts.
What I have bought so far:
Motherboard: Intel Desktop Motherboard LGA1155 DZ77BH55K (It was on Amazon Lightning Deals so i got it for $89 instead of its normal $169. otherwise i probably would have picked a different mobo.)
Storage: Kingston 120gb solid state drive and Seagate Barracuda 3 TB 7200RPM. ($220 overall)
What i need:
CPU: either i5-3470 or i5-3570k (The motherboard is supposed to be good for O.C. but i've never done that so that's not a major issue for me in picking cpu although if its not too hard i might learn how to do that in the future.)
Case (i need something that would give me best functionality and looks cool if you can but functionality is most important.)
Memory ( I read that there was a problem with some types of RAM on this motherboard so im not sure what i need exactly but i want about 8GB)
Video Card (I want to play games but I'm not a heavy PC Gamer (i am for ps3 though
). I surf the internet a lot, download heavy files, and use animation and drawing software. I'm also studying engineering so in the future i'll use autocad and some other stuff like that. So is the integrated graphics enough or do i need something better? and if so what do you recommend.)
Cooling unit: Do i really need one?
And as a general question, overall would this computer be able to last me 5+ years without being obsolete?
Thanks for all the Help!!!!
As you have a Z77 motherboard, there is no point, in not getting the unlocked i5-3570K. Anyway, it has better graphics, than most of the other i5s. If you have access to a Microcentre, they've currently got about $45 off the i5-3570K, making it cheaper than lesser i5s. Even if you can't use that offer, it's still worth getting that one.
Unless, and until, you overclock, the stock cooler, that comes with it, is fine. You will need to upgrade that when overclocking.
I'm not aware of any unusual needs, in terms of RAM, for mobo. You should get low profile RAM (to avoid a clash, if you fit aftermarket CPU cooler), with voltage 1.5v or lower. Suggest GSKill Ares, Crucial Ballistix Sport, or Corsair CML. Ideally you should use a matched pair of RAM, so for 8GB get a pair (2x4GB). 1600MHz Cas9 DDR3 is ideal.
For a case, the best quality, not to big, at reasonable price, is Corsair Carbide 300R, but there are plenty of others. Almost any mid tower ATX would be fine, if you avoid the real cheapies. It's important YOU like case, it's going to be sat in front of you, for a while. If you pick a couple YOU like, can advise if one is "best".
You probably need a graphics card. On board graphics isn't bad, but not really up to much gaming. Question is which? I would check, if any software you are going to use, has a specific requirement. Then it's a question of what funds left, after everything else, to get best possible GPU. If you say what money left for GPU, could advise on best one. Also if you give monitor resolution, gives better idea, what you really NEED.
As for life before becoming obsolete, basically if you've done the best you can, it will last the longest. Newer tech will be brought out, of course, but it's a question of how much more demanding software becomes, before today's tech gets too slow. No reason why it shouldn't still be going, and reasonably competetent in 5 years, it's a question of how up to date you want to keep.
