Buying new parts in less then an hour, help please!
okay, a buddy of mine suggested these parts.. my budget is around $700
$219.99 - Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor
$79.99 - BIOSTAR TZ77B LGA 1155 Intel Z77 ATX Intel Motherboard
$29.99 - Kingston HyperX XMP Blu Red Series 8GB (2 x 4GB) 240-Pin DDR3 1600MHz RAM
$179.99 - VisionTek Radeon HD 7850 2GB Video Card (Farcry3+Medal of Honor free)
$34.99 - RAIDMAX HYBRID 2 RX-630SS 630W Modular Power Supply
$79.99 - Seagate Barracuda 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive
$21.99 - GIGABYTE GZ-F5HEB Black SECC Steel / ABS ATX Mid Tower Computer Case
$16.99 - SAMSUNG DVD Burner
$99.99 - Microsoft Windows 7 Home Premium SP1 64-bit - OEM
Total - $763.91
i wish i had links to all the parts from newegg but he posted this from another forum.. it seems like everything is good but im concerned about the graphics card since i have never heard of the brand, nor does it have reviews or any kind of rating.. im sure this configuration isnt perfect to those who are more experienced so if you guys could tweek what i have into something more solid that would be greatly appreciated! ive been looking at parts all day and i just cant decide
1 answer Last reply
More about buying parts hour please
  1. Would be more concerned about the PSU than the GPU. RAIDMAX is a brand well known for making horrible Power Supplies. Gonna have to get a better quality unit.
    Given your budget, recommend this.
    Corsair Builder 500W, 80+ Bronze. $60 ($20 rebate)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027&Tpk=Corsair%20500w
    RAM is no good, cant have 1.65v RAM on an Intel system.
    Patriot Viper 8GB (2x4GB) 1600Mhz CL9 1.5v. $35 ($10 rebate)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820220685
    Otherwise should be good, if a little budget oriented. I would advise downgrading the GPU to a 7770 and freeing up ~$100 so you can get better a better PSU, case and such. But the ultimate decision if yours.
New Build Systems Product
