Monitor and GPU help
Hi, so I connected my computer to my monitor with a DVI to HDMI cord to get hdmi on my computer, the monitor is a 32" Widescreen 1920x1080 Sceptre X325BV-FHD LCD HDTV w/ Built-in Speakers, VGA & HDMI-Input and my GPU is a GTX 690. But whenever I try put the monitor onto HDMI at 1920x1080 the monitor cuts out the top and bottom of what should be displayed, and by that I mean that you cant see the bottom start menu bar. Any help is good help. Thanks for reading this.
1 answer Last reply
More about monitor help
  1. the 32inch monitor you have is actually a tv so it will have some image aspect ratio built in...go into the tv menu and change the aspect ratio to "just scan" that should fix your problem...if it doesnt report back
Graphics Cards Computer Monitors HDMI Graphics
