Signal strength problem
hi,
i have being getting problem since two month. the main problem of the router is that , it gets disconnected time to time very often creating irritation and a lot of problem.. wtih very low link strength
1 answer Last reply
More about signal strength problem
  1. If you are getting low signal when close to the router, try a firmware update. If that does not fix it, replace it. There are a few routers known to develop issues, especially with wireless stability.
Routers Connection Networking
