Closed Solved
Problem with AMD RADEON HD 7670 working
I have a laptop with given specs:
Intel(R) Core i5-2450M CPU @2.50GHz
RAM 4.00GB
GRAPHICS:
INTERNAL- Intel HD Graphics 3000
DEDICATED- Radeon (TM) HD 7670M
HDD- 500GB.
in device manager both the display adapters are shown to be working properly.
but i think that my RADEON graphic card is not working. please tell me how to know which graphic card is working in my system.
On the display tab in dxdiag, only the Intel HD Graphics 3000is being shown.
PLEASE HELP.
6 answers Last reply Best Answer
More about problem radeon 7670 working
  1. Since you have a laptop, power saving is a big priority. As such, the 7670m is shut down most of the time to save power, it only turns on when there is a high graphics load, such as a game. You can force the 7670m on all the time by setting your laptop to high performance power mode, and disabling the Intel HD 3000, but that will burn through your battery quicker. Are you suffering poor performance in games? If so, which ones? The 7670m isn't that fast, with really demanding games, the 7670m will choke if you push your graphics settings too high.
  2. Best answer
    More information needs to be given. What do you mean by "not working?" Just because it doesn't show up in DXDIAG doesn't mean anything. Do you still have options to configure the switchable graphics through the AMD control panel? If so, have you assigned applications to the "High Performance" settings? If you have done this, and you try to run a game, does the game run better than if you have it set to "Power Saving?" If it does, then your switchable graphics is working fine.
    If, for some reason, you notice no performance increase, it is possible that you have the switchable graphics disabled and you are probably on a battery. There is a BIOS setting for that, you can see an example here:
    http://imageshack.us/photo/my-images/268/79500144.jpg/
    For a picture of the AMD Catalyst Control Center configuration screen for switchable graphics, look here:
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c03048374&lc=en&cc=us&dlc=en
    Edit: Dxdiag, along with Windows Experience Index, is no way to gauge the performance of and functionality of your computer with any switchable graphics. You can get logs from dxdiag that can help solve conflict or driver issues but that's about it.
  3. If you don't want to use your HD3000, you can disable Ultra low Power saving in the registry.
    Go to regedit @ run
    search for EnableUlps
    switch the value to 0
    then your 7670M will always show up
  4. Best answer selected by devansh1993.
  5. thank you. i think the problem was my system running on power saver mode. Games are running fine.
    In reference to the link provided:
    my bios isn't showing the 'Switchable Graphic Mode' option in system configuration tab or elsewere.
    do i need to to update my bios?
  6. This topic has been closed by Mousemonkey
Radeon Intel HD Graphics
