Need help should i buy this and for how much please help
Hello,
these are the specs of the desktop. I was just wondering if it would play games such as bf3 and kind of new games at medium to high settings. Also how much you would pay for it
AMD Phenom x4 Quad Core 3.3
8GB DDR3
1TB HDD Seagate 7200 RPM
1GB Asus Geforce GTX550Ti GFX Card - Hdmi Output.
700W Power Supply
DVD Rewriter
Windows 7 Home Premium 64Bit
im new to this so please help
3 answers Last reply
More about need help
  1. If you play BF3 at 1680x1050 or less (and have a fast internet connection), you should be able to get good frame rates with mid/high settings. The Phenom II X4 850 is an older CPU without a level 3 cache, and you don't mention which motherboard it comes with. If it's a used system in good condition, maybe $400 max. Assuming it doesn't come with an O/S.
    Thank you, i'm not sure what motherboard it has since its on ebay and thats all the listing says I will have to ask the seller thanks for your help
  3. I probably wouldn't pay more than $450.
    Those are some pretty dismal specs. Do you have a budget?
Prebuilt Games Systems
