Hello,
I have an HD 6950 and it is having some heat issues. When idle, it stays at around 45-47 degrees celsius. This is fine, right? But when under stress (WoW @ ultra 2560x1440), it goes to 80 degrees celsius and usually stays at 75-83, 83 being the highest it's ever gotten.
I'm not sure why this is happening. My PSU is a few inches under it, but it expels heat out the back of the case. The card is getting sufficient airflow. HWMonitor shows everything else having a nice temperature while gaming.
I have also noticed that when it is at 80°C GPU-Z shows the card is only using 30-35% of the fan and it shows 1900-2100 RPM.
What could be the problem?
Also, I'm thinking of getting an HD 7970. Will it be able to play WoW 2560x1440 Ultra @ 60fps? I assume it can from it's benchmarks, but I haven't actually found one for WoW.
